查看: 627|回复: 0
极致之作!宝马E91改装气动避震解决舒适及炫酷外观
发表于 2020-11-4 15:40:26 | 只看该作者 |只看大图 回帖奖励 |倒序浏览 |阅读模式
The ultimate work! BMW E91 modified pneumatic shock absorber for comfort and cool appearance
e91是底盘代号,这代表第五代宝马3系的旅行版车型。第五代宝马3系的四门车型代号为e90,双门车型代号为e92,双门敞篷车型代号为e93,四门旅行版车型代号为e91。
E91 is the chassis code name, which represents the fifth generation of BMW 3-Series travel model. The code of the fifth generation BMW 3 series is E90, E92, E93 and E91.
Hellaflush has become an international appearance trend of refitted cars. With the development and progress of domestic refitted cars, more and more are accepted by the public. HF model has also become a symbol of taste
Let's break down the word hellaflush = Hella flush, that is, there are two parts, one is Hella, the other is flush. Hella is the abbreviation of "hell of", which means special, extraordinary, absolute and super; flush means flush. Therefore, two points should be understood here: 1. The formation of hellaflush must first satisfy the requirements of flush, that is, flat wheel tires, and then be qualified to make efforts from flush to hellaflush; 2. The body height must be as low as possible, and there must be no gap between the tire and the leaf plate from the side of the car.
