查看: 609|回复: 0
AIRBFT铝合金鱼雷气罐到货,一体成型非焊接强度更高更可靠,精细抛光表面处理
发表于 2020-11-4 15:09:00 | 只看该作者 |只看大图 回帖奖励 |倒序浏览 |阅读模式
Airbft aluminum alloy torpedo gas tank arrived, one-piece forming, higher non welding strength, more reliable, fine polishing surface treatment
The working principle of pneumatic shock absorber is to change the height of the car by controlling the air pressure. It includes the toothed shock absorber, air pressure control system and electronic control system. Don't worry about a lot of people who don't want to drive at the car show.
