查看: 636|回复: 0
“绝非等闲之辈”大众R36改装气动避震案例
发表于 2020-11-3 16:17:51 | 只看该作者 |只看大图 回帖奖励 |倒序浏览 |阅读模式
The case of Volkswagen R36 refitting pneumatic shock absorber
大众R36是德国大众汽车旗下R系R36一款汽车,承袭R系高性能运动轿车的动感基因,搭载V6 3.6L FSI发动机,300马力,百公里加速仅用时5.6秒。
大众R36出自于前沿的大众汽车个性化部门(VW Individual),是运动车型系列的又一员干将。大众R36在整体的外型上,依然延续“R”运动车型家族的优良基因。车身前后的“R36”标识成为这款车型独一无二的身份象征。 间隔线
作为同级别运动车型的典型代表,大众R36的整体设计自信沉稳而又激情无限。轻踏油门,您即能感受到其强劲动力。
Volkswagen R36 is a R-Series R36 car of German Volkswagen. It inherits the dynamic gene of R-Series high-performance sports car. It is equipped with V6 3.6L FSI engine, 300 horsepower, and takes only 5.6 seconds to accelerate 100 km.
Volkswagen R36 comes from the forefront of VW individual, and is another member of the sports car series. On the overall appearance, Volkswagen R36 still continues the excellent gene of "R" sports car family. The "R36" logo on the front and rear of the body has become the unique identity symbol of this model. parting line
As a typical representative of sports vehicles of the same level, the overall design of Volkswagen R36 is confident, steady and passionate. Step on the gas pedal, you can feel its strong power.
The shock absorber is used to suppress the shock of the shock absorber. Although the shock absorption spring can filter the vibration of the road surface when passing through the uneven road surface, the spring itself will have reciprocating motion, and the shock absorber is used to restrain the spring jumping.
