查看: 653|回复: 0
史上最美一代奔驰W211AIRBFT气动避震三段记忆姿态达成
发表于 2020-11-3 16:06:25 | 只看该作者 |只看大图 回帖奖励 |倒序浏览 |阅读模式
The most beautiful generation of Mercedes Benz w211airbft achieves three stage memory posture of aerodynamic shock absorption
这是奔驰历史上最成功的一代E级车,底盘代号W211,诞生于2003年,随后被北京奔驰正式合资生产。而这代W211的旅行车,在国内几乎寻觅不到踪影。也许一些使馆用车可能会找到。这一代E级为什么会被奉为经典,当然就是因为它的设计完全切中了奔驰这个品牌最核心的价值,就是优雅和极致的设计感。车身的各处比例都非常完美,饱满的线条和四眼灯,引领了设计上的一个风潮。
This is the most successful E-class car in Benz's history. The chassis code named W211 was born in 2003, and then it was officially produced by Beijing Benz. And this generation of W211 station wagon can hardly be found in China. Maybe some embassy cars will be found. Why this generation of E-class is regarded as a classic is, of course, because its design is completely in line with the core value of Mercedes Benz brand, which is elegant and ultimate design sense. All parts of the body are perfectly proportioned. The full lines and four eye lights lead to a trend in design.
气动避震一般只有豪华车才有配套,是一种舒适和高端的象征,一般的车型都不具备配套空气悬挂,改装气动避震就成了车主的最佳选择,而且比原车空气悬挂有更大的优势,升降行程大,即可以高,也可以低,完美的呈现改装的魅力!看看这辆四眼奔驰W211改装空气悬挂的效果!
Generally, only luxury cars have matching pneumatic shock absorbers, which is a symbol of comfort and high-end. Ordinary models do not have matching air suspension. Refitting pneumatic shock absorbers has become the best choice for car owners. Moreover, it has greater advantages than the original car air suspension. The lift travel is large, which can be high or low, presenting the charm of refitting perfectly! Take a look at the air suspension effect of this four eye Mercedes Benz W211!
汽车避震是由弹簧和减震器共同组成的。
