查看: 636|回复: 0
奔驰V260AIRBFT气动避震套件施工
发表于 2020-11-3 15:54:56 | 只看该作者 |只看大图 回帖奖励 |倒序浏览 |阅读模式
Construction of Mercedes Benz V260 airbft pneumatic shock absorber
梅赛德斯-奔驰V级 MPV的独特设计令人过目不忘,惬意宽阔的空间里,铭刻着值得被时间细细诉说的故事。经由设计师的精心设计,V级MPV拥有宽敞灵活的内部空间应用方案,像把起居室搬到公路上,为驾乘者带来难以言喻的享受和体验。
The unique design of Mercedes Benz V-Class MPV is unforgettable. The comfortable and wide space is engraved with stories worth telling in detail. Through the designer's careful design, the V-Class MPV has a spacious and flexible internal space application scheme, such as moving the living room to the road, which brings inexpressible enjoyment and experience for drivers and passengers.
从买车那一刻起,我想每一个人都会想着让自己的车变得更好,更美,改装就成了心中的一个梦,只要有机会就会把车子拿去改装,让它变得更有魅力。气动避震的出现让很多玩家按耐不住心中的冲动,一心只想让自己的车趴下!今天我们来分享奔驰V260改装AIRBFT空气悬挂的舒适性体验!
From the moment I bought a car, I think everyone will want to make their car better and more beautiful. Refitting has become a dream in my heart. As long as I have the opportunity, I will refit the car to make it more attractive. The emergence of pneumatic shock absorbers makes many players can't bear the impulse in their hearts and just want to let their cars lie down! Today, let's share the comfort experience of air suspension of Mercedes Benz V260 refitting airbft!
喜欢玩改装避震系统的发烧友,空气避震是话题里面最贵的一款。
听起来非常方便,气动避震到底是什么原理呢?
it's not easy to choose the right pneumatic shock absorber. The grades of pneumatic shock absorbers are different. There are also various brands.
