查看: 633|回复: 0
5加仑鱼雷气罐到货表面精抛处理,细致如你,光滑如初,不过需要精心呵护哦
发表于 2020-11-3 14:54:14 | 只看该作者 |只看大图 回帖奖励 |倒序浏览 |阅读模式
The surface of the 5-gallon torpedo gas tank is finely polished, as delicate as you are, smooth as before, but it needs careful care
气动避震改装现在在国内已经成为一种潮流,玩车的人几乎人人都知道气动避震,但由于价格和产品稳定性让很多人望而却步,价格高是因为我们为保证产品质量,多数的配件采用国外进口,但是说在使用过程中出现的一些质量问题主要是由三个原因引起,一是安装环节导致,气动避震一定要找专业的安装人员进行安装调教,否则会因安装位不准确对产品造成损害、二是没有正确的使用和保养、三也是最少见的,是产品配件自身出的质量问题,如气泵衰竭,电脑不稳定等因素。所以气动避震的安装使用一定要严格按照生产厂家的要求来进行安装。那么都有哪些车型可以改装气动避震悬挂,在国内AIRBFT气动悬挂应该是车型最全的一个品牌,几乎覆盖所有车型,新车也可快速开发定制.
Pneumatic shock absorber refitting has become a trend in China. Almost everyone who plays with cars knows pneumatic shock absorbers. But because of the price and product stability, many people are deterred. The high price is because we import most of the accessories from abroad to ensure the product quality. However, some quality problems in the use process are mainly caused by three reasons. One is safety Due to the installation process, we must find professional installation personnel for installation and adjustment. Otherwise, the product will be damaged due to inaccurate installation position. Second, there is no correct use and maintenance. Third, it is the most rare. It is the quality problems of product accessories themselves, such as air pump exhaustion, computer instability and other factors. Therefore, the installation and use of pneumatic shock absorber must be in strict accordance with the requirements of the manufacturer. In China, airbft pneumatic suspension should be a brand with the most complete models, covering almost all models. New cars can also be developed and customized quickly
