查看: 729|回复: 0
福特蒙迪欧改装气动避震案例 低姿态魅力共享
发表于 2020-11-1 15:40:46 | 只看该作者 |只看大图 回帖奖励 |倒序浏览 |阅读模式
Ford Mondeo retrofit aerodynamic shock absorber case low profile charm sharing
福特蒙迪欧(Mondeo)是福特汽车公司在世界多个市场进行销售的一款中型轿车。
蒙迪欧“Mondeo”源于法语中“Monde”一词,是对优雅气质的描绘,是经典与尊贵的象征。“Mondeo”又有“Mondial”之意,即“全世界”,福特汽车借此表达出一种俯瞰世界的气度。
Mondeo is a medium-sized car sold by Ford Motor Company in many markets around the world.
Mondeo, originated from the French word Monde, is a description of elegance and a symbol of classics and dignity. "Mondeo" also means "Mondial", which means "the whole world". Ford Motor expresses a kind of bearing of overlooking the world.
今天给大家分享的是福特蒙迪欧的改装案例,改装风格是Hellaflush低趴风,蒙迪欧的外观设计很帅气是车友公认的,有小马丁之称,车主选择低姿态的改装风格真的是太对了,这个低趴效果给台马丁也不换啊!一起来欣赏一下这辆蒙迪欧改装气动避震的姿态魅力!
Today, I'd like to share with you the modification case of Ford Mondeo. The refitting style is hellaflush low lying style. The exterior design of Mondeo is very handsome, which is recognized by car owners. It's really right for car owners to choose low attitude refitting style. This low lying effect will not be changed for Martin! Let's enjoy the charm of this Mondeo modified pneumatic shock absorber!
