查看: 643|回复: 0
宝马F30改装气动避震 超级低趴姿态
发表于 2020-10-31 15:37:54 | 只看该作者 |只看大图 回帖奖励 |倒序浏览 |阅读模式
宝马F30改装气动避震 超级低趴姿态
BMW F30 refitted pneumatic shock absorber super low prone posture
BMW F30是BMW对其第六代3系列中型车制定的企业内部标识,分别在慕尼黑、雷根斯堡、沈阳和罗斯林的BMW工厂生产。
它自2012年起作为E90的继任车型,F30的官方发布仪式是在2011年10月14日于慕尼黑的BMW总部举行。首辆三厢版本则是自2012年2月11日起发售。
BMW F30 is the internal logo of BMW for its sixth generation 3 Series medium-sized vehicles. It is produced in BMW factories in Munich, Regensburg, Shenyang and Roslin.
As the successor of the E90 since 2012, the official launch ceremony of F30 was held at BMW headquarters in Munich on October 14, 2011. The first three compartment version was launched on February 11, 2012.
气压避震改装风格发展至今,总体出现两个方向,一类是低趴的车身配合夸张的宽体或相对凸显战斗气息;而另一种则是尽量保证车身的干净、整洁,以原厂升级或进行少许替换,将原厂的设计风格保留。眼前这台宝马f30的改装便是遵循了后者的思路,在自身 的基础上进行了气压避震的改装,使车身呈现出十分干净整洁而且高贵的低趴效果。
Up to now, there are two directions in the development of pneumatic shock absorber refitting style. One is the low lying body with exaggerated wide body or relatively highlighting the fighting atmosphere; the other is to try to ensure that the body is clean and tidy, upgrade or replace it with the original factory, so as to retain the original design style. At present, the refitting of the BMW F30 is to follow the latter's idea. On the basis of its own, the refitting of pneumatic shock absorber makes the body present a very clean, clean and noble low lying effect.
