查看: 659|回复: 0
奔驰E200L简单造型安装AIRBFT气动避震
发表于 2020-10-28 16:37:19 | 只看该作者 |只看大图 回帖奖励 |倒序浏览 |阅读模式
Simple design and installation of airbft pneumatic shock absorber for Benz e200l
奔驰E200 作为全球最具吸引力的双门轿跑车,E级双门轿跑车自2009年登陆中国以来,便以无出其右的优雅气质和全球顶级的环保科技,成为众多精英人士梦寐以求的轿跑车。此次E 200双门轿跑车的引进,进一步扩充了梅赛德斯-奔驰E级双门轿跑车的产品阵容,同时让更多自信、成功、个性鲜明精英人士更轻松的拥有这款梦想座驾。
Mercedes Benz E200 is the most attractive coupe in the world. Since its landing in China in 2009, the E-Class coupe has become the dream car of many elites with its unparalleled elegance and world-class environmental protection technology. The introduction of E200 coupe further expands the product lineup of Mercedes Benz E-class coupe, and makes it easier for more confident, successful and distinctive elites to own this dream car.
汽车改装属于汽车后市场的一种产物,许多车型因为原厂的设计比较平庸,不能满足玩家的要求,因此就出现了改装行业的繁荣现象,气动避震悬挂的改装属于一种外观的姿态改装,以贴地的美感博的玩家们的好感,视觉的强烈冲击和反常规状态引起强烈的共鸣,一起来欣赏 改装鉴赏|奔驰E200改装气动避震低姿态案例
Car refitting is a product of the automotive aftermarket. Many models can't meet the requirements of the players because of the mediocre design of the original factory. Therefore, the refitting of the pneumatic shock absorber suspension is a kind of appearance posture modification, which causes strong resonance with the good feeling of the players close to the ground, strong visual impact and unconventional state, Let's enjoy the refitting appreciation of Mercedes Benz E200's low attitude aerodynamic shock absorber
