查看: 781|回复: 0
“击中年轻人的灵魂”宝马4系敞篷升级气动避震悬挂打造极致低趴
发表于 2020-10-28 16:22:06 | 只看该作者 |只看大图 回帖奖励 |倒序浏览 |阅读模式
"Hit the soul of young people" BMW 4 Series Convertible upgraded pneumatic shock suspension for extreme low lying
4系全新的设计风格和无法掩盖的运动气息,都让它变得更加璀璨夺目。宝马430i就显得拉风而不失优雅,它的尺寸与原车姿态得到了保留,在敞篷开合之间,好像它独有的多变性正好与这个时代的多元化属性刚好契合以至于全新宝马M3/M4都以4系为基础进行设计开发,这一点也足以证明它的实力绝对不可小觑。
通过F时代的低迷,4系车型仿佛从沉睡中醒来,它已然知道如果仅是骨子里发生变化,很可能在这样浮华的市场中会一蹶不振,所以只有全新的设计才能让消费者得到花钱的满足感。
4 series of new design style and can not hide the movement of breath, make it become more dazzling. BMW 430I is elegant and elegant. Its size and original vehicle posture have been retained. Between the opening and closing of the convertible, it seems that its unique variability is just in line with the diversified attributes of this era, so that the new BMW M3 / M4 is designed and developed on the basis of 4 series, which is enough to prove that its strength can not be underestimated.
Through the downturn of the f era, the 4-series model seems to wake up from a deep sleep. It already knows that if there is only a change in the bone, it is likely to collapse in such a flashy market. Therefore, only a new design can make consumers feel satisfied with spending money.
一低遮百丑,前些年降低车身主要是改装绞牙避震,虽然车子降低了,但是弊端也很明显,车子不能见烂路,不然就是蹭到底盘,真是很难受,随着气动悬挂的出现,很多绞牙党毫不犹豫的升级气动或者直接更换整套气动悬挂,比以前更低,关键这种随时升降的感觉真是很爽!
A few years ago, the main way to reduce the car's body was to refit the hinge teeth for shock absorption. Although the car has been reduced, the disadvantages are obvious. The car can't see rotten roads, or it will rub against the chassis. It's really hard. With the emergence of pneumatic suspension, many of the hinge party have no hesitation to upgrade the pneumatic or directly replace the whole set of pneumatic suspension, which is lower than before. The key is the feeling of lifting and lowering at any time It's so cool!
