查看: 672|回复: 0
太霸气了,福特野马改装气动避震悬挂的完美姿态
发表于 2020-10-25 16:09:53 | 只看该作者 |只看大图 回帖奖励 |倒序浏览 |阅读模式
由于Mustang I野马概念车的两座设计实用性太低,被福特高层驳回后,1963年10月,福特推出了Mustang II概念车,将布局改为了发动机前置,并采用四座布局。1964年4月17日,经过福特团队反复论证、修改后的第一代量产版Mustang于纽约世博会上正式发布,野马自此正式向全世界展示了它的风范,在刚推出时的价格为:2368美元。福特的时间表把握得非常之巧,此时正值战后生育高峰期的一代刚刚进入购车的年龄,这一代人对车的要求与其父母大相径庭,他们想张扬自己的个性,野马应运而生。
In 1962, Ford developed Mustang's first concept car, Mustang I. It's a two seater sports car with a central engine. The name of Mustang is to commemorate the legendary P-51 Mustang fighter in World War II.
As the Mustang I Mustang concept car's two seat design was too low for practical use, it was rejected by Ford's senior management. In October 1963, Ford launched Mustang II concept car, changing the layout to the front of the engine and adopting a four seat layout. On April 17, 1964, Mustang, the first generation of mass production version, was officially released at the New York World Expo after repeated demonstration and modification by the Ford team. Since then, Mustang has officially demonstrated its style to the world. The price at the time of its launch was 2368 US dollars. Ford's schedule is very skillful. At this time, the generation of postwar baby boomers is just entering the age of buying cars. This generation's requirements for cars are quite different from their parents. They want to show their personality, so Mustang emerges as the times require.
总是发“趴”在地上的车好多人不理解疑问也多,就通俗易懂的解释一下,气动,通过改装四支“空气避震+控制器”从而达到在车内随意调节车身高度的目的。很多品牌高端配置车型也会有,它叫做“底盘升降”差别在哪?升的没我们高,降的没我们低,升降速度没我们快。 今天分享一款酷炫的福特野马改装的气动避震!
A lot of people don't understand and have a lot of questions about the car that is always lying on the ground. It is easy to explain that pneumatic, by refitting four "air shock absorbers + controllers", can achieve the purpose of adjusting the height of the body in the car at will. Many brands have high-end configuration models, which are called "chassis lifting". What is the difference? The rising is not as high as ours, the descending is not as low as ours, and the ascending and descending speed is not as fast as ours. Today share a cool Ford Mustang modified pneumatic shock absorber!
上面说了4点好处,其实啊,大多数车友是为了更好的趴低……车子低了对我们来说才是美,才有范儿。
还能够享受周围人们的注目,也是一件极其满足虚荣心的事情。
There are four advantages mentioned above. In fact, most of the riders want to lower themselves better The lower the car is, the better it is.
t is also a matter of great vanity to be able to enjoy the attention of people around.
