查看: 746|回复: 0
十代思域改装界网红AIRBFT气动避震低姿态鉴赏
发表于 2020-10-25 15:51:55 | 只看该作者 |只看大图 回帖奖励 |倒序浏览 |阅读模式
Appreciation of low attitude aerodynamic shock absorbers of ten generations of civic refitted red airbft
Honda Civic has launched a variety of models to cater to the tastes of consumers in different countries, including three hatchback hatchback hatchback coupe, hybrid and five door RV. The Honda Civic and Dongfeng Honda's existing models, Honda CR-V, come from the same production platform. The two models use the same chassis, which provides technical preconditions for the domestic Honda Civic. After 40 years of experience and continuous evolution in 10 generations of deduction, today's 10th generation Civic (Civic) gathers many advanced technologies of leading times, presenting you with a charming work with a sense of future and science and technology.
十代思域从新车发布以来,便受到广大车友的关注,最开始的狂热到后来的超跑事件,变得异常低调,但是改装的玩家依然很多,主要是外观姿态的改装,今天我们来欣赏这辆有呼市阵地改分享的十代 思域 改装AIRBFT气动避震的低姿态魅力!
Since the launch of the new car, the ten generation Civic has attracted the attention of the majority of riders. From the initial fanaticism to the later overtaking event, it has become extremely low-key. However, there are still many players who have been refitted, mainly the appearance and posture modification. Today, let's enjoy the low-profile charm of this 10 generation Civic modified airbft with Hohhot position reform!
The popular word in the field of modification is "change from 100 to reduced to first" I add a word, low lying is the king! If there is no pneumatic shock proof modification, I feel like walking corpse, with a bright appearance and no soul! It is called a low cover hundred ugly, pneumatic shock proof retrofit is the most critical to improve the quality of the vehicle!
喜欢玩改装避震系统的发烧友,空气避震是话题里面最贵的一款。这是可以控制车身高度高低的配置,随时变成低趴车,也能变成正常的高度。听起来非常方便,气动避震到底是什么原理呢?
要选择合适的气动避震并不简单,气动避震的等级不同。品牌也是五花八门。目前市场上主要分两种气动方式,机械式气动避震和电子式气动避震,不用明说,光听见电子这两个字,就知道技术含量比较高。价格上,比机械式气动避震要高,但是稳定性上没有机械式这么可靠。气动避震是一件比较精密的配件,和原厂避震相比完全是一个天一个地。
气动避震上各有一个弹性橡胶气囊,气囊其实是一个密闭的压力缸,里面充满了惰性气体和油气混合物。腔体内的压力要比大气压高几倍甚至几十倍左右,再利用活塞杆的横截面积小于活塞的横截面积,来产生压力差,使活塞杆运动。因为气动避震是比较精密的部件,有气罐装置,不适合在颠簸路段进行剧烈的驾驶。
Like to play modified shock absorber system enthusiasts, air shock absorber is one of the most expensive topics. This is a configuration that can control the height of the body. It can become a low prone car at any time, and can also become a normal height. It sounds very convenient. What is the principle of pneumatic shock absorption?
It's not easy to choose the right pneumatic shock absorber. The grades of pneumatic shock absorbers are different. There are also various brands. At present, there are mainly two kinds of pneumatic shock absorbers in the market, mechanical pneumatic shock absorbers and electronic pneumatic shock absorbers. Needless to say, just hearing the word "electronic", you will know that the technical content is relatively high. The price is higher than the mechanical pneumatic shock absorber, but the stability is not as reliable as the mechanical type. Pneumatic shock absorber is a more precise accessory, compared with the original shock absorber, it is completely one day a place.
There is an elastic rubber air bag on the pneumatic shock absorber. The air bag is actually a closed pressure cylinder filled with inert gas and oil-gas mixture. The pressure in the chamber is several times or even dozens of times higher than that of atmospheric pressure, and then the cross-sectional area of the piston rod is smaller than that of the piston to generate pressure difference and make the piston rod move. Because the pneumatic shock absorber is a more precise part and has an air tank device, it is not suitable for severe driving on bumpy roads.
