查看: 611|回复: 0
宝马E92改装气动避震引领低趴改装风潮
发表于 2020-10-25 15:06:37 | 只看该作者 |只看大图 回帖奖励 |倒序浏览 |阅读模式
宝马E92改装气动避震引领低趴改装风潮
BMW E92 refitting pneumatic shock absorber leads the trend of low lying refitting
气压避震改装风格发展至今,总体出现两个方向,一类是低趴的车身配合夸张的宽体或相对凸显战斗气息;而另一种则是尽量保证车身的干净、整洁,以原厂升级或进行少许替换,将原厂的设计风格保留。眼前这台宝马改装便是遵循了后者的思路,在金色大脚的基础上进行了气压避震的改装,使车身呈现出十分干净整洁而且高贵的低趴效果。
Up to now, there are two directions in the development of pneumatic shock absorber refitting style. One is the low lying body with exaggerated wide body or relatively highlighting the fighting atmosphere; the other is to try to ensure that the body is clean and tidy, upgrade or replace it with the original factory, so as to retain the original design style. At present, the refitting of this BMW follows the latter's idea. On the basis of the golden foot, the modification of pneumatic shock absorber is carried out, which makes the body present a very clean, clean and noble low lying effect.
