查看: 732|回复: 0
青春就能“永恒”十代思域改装网红低趴范气动避震
发表于 2020-10-24 15:29:00 | 只看该作者 |只看大图 回帖奖励 |倒序浏览 |阅读模式
Youth can be "eternal" ten generation Civic refitting net red low fan aerodynamic shock absorber
Honda Civic has launched a variety of models to cater to the tastes of consumers in different countries, including three hatchback hatchback hatchback coupe, hybrid and five door RV. The Honda Civic and Dongfeng Honda's existing models, Honda CR-V, come from the same production platform. The two models use the same chassis, which provides technical preconditions for the domestic Honda Civic. After 40 years of experience and continuous evolution in 10 generations of deduction, today's 10th generation Civic (Civic) gathers many advanced technologies of leading times, presenting you with a charming work with a sense of future and science and technology.
喜欢玩改装避震系统的发烧友,空气避震是话题里面最贵的一款。
听起来非常方便,气动避震到底是什么原理呢?
