查看: 821|回复: 0
”期待未来,更把握现在”奥迪Q5气动避震悬挂上身变身完美绅士
发表于 2020-10-22 16:05:27 | 只看该作者 |只看大图 回帖奖励 |倒序浏览 |阅读模式
”Looking forward to the future and grasping the present
奥迪Q5是一款动感而全能的SUV,凭借优异的性能和技术优势,米其林Pilot Preceda PP2高性能运动轮胎近日成为高档中型SUV奥迪Q5的原配轮胎。
奥迪Q5它完美融合了运动型轿车的车身设计、高效动力和灵敏操控、SUV的越野安全奥迪Q5   性能以及旅行车的出色舒适性和灵活多变的内部空间,延续了第三代顶级SUV奥迪Q7的诸多优势特性。强劲的绿色高效发动机、quattro全时四驱系统以及灵敏的行驶机构,使其无论是公路行驶还是越野前行都游刃有余。此外,7速双离合Stronic变速器和“奥迪    驾驶模式选项”等全新技术的应用再次诠释了奥迪“突破科技 启迪未来”的品牌理念。
Audi Q5 is a dynamic and all-round SUV. With its excellent performance and technical advantages, Michelin pilot preceda PP2 high-performance sports tire has recently become the original tire of Audi Q5, a high-end medium-sized SUV.
Audi Q5 perfectly integrates the body design of sports cars, efficient power and sensitive handling, off-road safety of SUV, excellent comfort and flexible interior space of station wagon, which continues many advantages of Audi Q7, the third generation of top SUV. Strong green and efficient engine, Quattro all-time four-wheel drive system and sensitive driving mechanism make it easy to drive on road or off-road. In addition, the application of new technologies such as 7-speed dual clutch tronic transmission and "Audi driving mode options" reinterprets Audi's brand concept of "breaking through technology and enlightening the future".
也不知道从什么时候开始,时下最流行的改装风格Hellaflush低趴风,也渐渐吹起来了,在SUV车型中开始火热起来, 谁也不能抵挡它的魅力诱惑, 这辆奥迪Q5安装气动避震悬挂通过低趴改装之后,变身完美低趴绅士。看看改装Hellaflush风格的奥迪Q5会有怎么的低趴效果!
I don't know when, hellaflush low lying wind, the most popular modification style, is gradually blowing up. It is becoming more and more popular in SUV models. No one can resist its charm temptation. This Audi Q5 is equipped with pneumatic shock absorber suspension. After being refitted, it becomes a perfect low lying gentleman. See how the modified hellaflush style Audi Q5 will have a low lying effect!
汽车避震是由弹簧和减震器共同组成的。
