打造属于自己的低趴姿态 马自达3改装气动避震
Create your own low prone posture Mazda 3 refitted pneumatic shock absorbers
Mazda3是长安马自达旗下的一款车系。Mazda3对底盘、车身、动力等方面的核心技术做出重大改进,极大地提高了产品动力性和豪华程度,产品档次大幅提升。
Mazda3在日本又称为“axela”,有5门掀背式两厢轿车和4门三厢轿车两种车款。国产装配排量主要为1.6升汽油发动机。Mazda3是一款很不错的运动性轿车,很受年轻人欢迎,特别是爱好汽车改装的消费者。从Mazda6开始,马自达的品牌形象焕然一新,个性、速度和进取精神取代了过去马自达 给人的平庸印象。尽管Mazda3采用新一代福特福克斯的平台,但外形上看不到任何福特的影子,相反,突出的运动感倒是让Mazda3的风格自成一家。
Mazda3 is a car line of Mazda in Chang'an. Mazda3 has made significant improvements in the core technologies of chassis, body and power, greatly improving the power and luxury of the products, and greatly improving the product grade.
Mazda3, also known as "Axela" in Japan, has two models of 5-door hatchback hatchback sedan and 4-door sedan. The domestic assembly displacement is mainly 1.6 L gasoline engine. Mazda3 is a very good sports car, very popular with young people, especially those who like car modification. Since Mazda6, Mazda's brand image has been completely new, and its personality, speed and enterprising spirit have replaced the mediocre impression of Mazda in the past. Although Mazda3 adopts the platform of the new generation Ford Focus, there is no shadow of Ford in the appearance. On the contrary, the outstanding sense of movement makes Mazda3 have its own style.
不知不觉,马自达3已经在国产内生产3代了,虽然越来越激进的设计风格更加顺应潮流,但是当我们静下心来的时候,还是会发现本文里的这代车型经过改装后,别有一分韵味。
Unconsciously, Mazda 3 has produced three generations in China. Although the more and more radical design style is more in line with the trend, when we calm down, we will still find that this generation of models in this paper after modification has a unique charm.
喜欢玩改装避震系统的发烧友,空气避震是话题里面最贵的一款。
听起来非常方便,气动避震到底是什么原理呢?
Like to play with the modified shock absorber system enthusiasts, air shock is the most expensive topic.
This is a configuration that can control the height of the body, and it can be turned into a low lying car at any time, and it can also become a normal height.
It sounds very convenient. What is the principle of aerodynamic shock avoidance?
It is not easy to choose the appropriate aerodynamic shock proof, and the level of the aerodynamic shock avoidance is different. Brands are also diverse.
At present, there are two main types of pneumatic modes in the market, mechanical pneumatic shock avoidance and electronic pneumatic shock avoidance. Needless to say, the technical content is relatively high when you hear the two words of electronic.
In price, it is higher than mechanical pneumatic shock proof, but the stability is not so reliable as mechanical type.
Pneumatic shock proof is a more precise accessory, compared with the original factory shock proof is a day by day.
There is an elastic rubber airbag on the pneumatic shock proof. The air bag is actually a closed pressure cylinder, which is filled with inert gas and oil-gas mixture. The pressure in the cavity is several times higher than the atmospheric pressure or even dozens of times. Then, the cross-sectional area of the piston rod is smaller than the cross-sectional area of the piston to generate pressure difference and make the piston rod move.
Because the pneumatic shock proof is a relatively precise component, with the air tank device, it is not suitable for driving violently in the bumpy road.
It is easy to cause chronic air leakage, cause unstable air pressure, increase the temperature in the air tank, and the pneumatic regulation will lose accuracy.
