查看: 712|回复: 0
能让人驾乘愉快的汽车-宝马6系气动避震的低姿态演绎
发表于 2020-10-20 15:07:18 | 只看该作者 |只看大图 回帖奖励 |倒序浏览 |阅读模式
BMW 6 series pneumatic shock absorber with low attitude
宝马6系是德国宝马专门为考究的驾驶者设计的汽车,1976年面世,1989年停产,这期间销量是8万6千辆,是宝马历史上最成功的一款箱式轿车。
时隔14年后,宝马决定复活6系,再次介入到这个大型豪华跑车市场中。 彰显了GT赛车的宝马6系核心理念。综合了运动跑车和豪华房车的优点于一身。BMW运动型双门汽车先前的款型也曾完美的达到了这一综合。
BMW 6 series is a car specially designed by German BMW for elegant drivers. It was launched in 1976 and stopped production in 1989. During this period, the sales volume was 86000, which is the most successful box car in BMW history.
After 14 years, BMW decided to resurrect the 6-series and intervene in this large luxury sports car market again. It shows the core concept of BMW 6 series of GT racing car. It combines the advantages of sports cars and luxury saloon cars. The BMW has reached the perfect combination of the previous model.
今天介绍的是改装气动避震玩低姿态的宝马6系,动感优雅的车身姿态在气动避震降低车身的帮助下体现的淋漓尽致!
Today, we introduce the BMW 6 series which is refitted with pneumatic shock absorbers to play a low attitude. The dynamic and elegant body posture is reflected incisively and vividly with the help of pneumatic shock absorber to lower the body!
