查看: 564|回复: 0
出彩更出色 福特野马改装气动避震悬挂的完美姿态
发表于 2020-10-18 15:26:03 | 只看该作者 |只看大图 回帖奖励 |倒序浏览 |阅读模式
Perfect posture of modified pneumatic shock suspension for Ford Mustang
In 1962, Ford developed Mustang's first concept car, Mustang I. It's a two seater sports car with a central engine. The name of Mustang is to commemorate the legendary P-51 Mustang fighter in World War II.
喜欢改装的朋友可以看过来,AIRBFT气动避震每天分享国内各种车型精彩的改装案例,供玩家们欣赏和借鉴,为中国的改装事业献出自己的一点点贡献,今天我们来欣赏福特野马改装AIRBFT气动避震悬挂,开启低趴之路的魅力!
Friends who like to refit can see it. Airbft pneumatic shock absorbers share wonderful retrofit cases of various domestic models every day for players to appreciate and learn from, and contribute a little bit to China's refitting cause. Today, we'd like to appreciate Ford Mustang refitting airbft pneumatic shock absorber suspension to open the road of low lying down!
气动避震的组成部分为控制系统和气动避震桶身两大类!
Pneumatic shock absorber consists of control system and pneumatic shock absorber barrel body!
Intelligent air replenishment and intelligent adjustment of vehicle level: in fact, the functions of these two functions are the same. For example, the body height is originally horizontal. If a fat man sits in the rear seat, the height of the rear side will be reduced. At this time, the computer will detect the height change at the rear, and respond in less than one second. The two air bags at the back will be inflated to maintain it Body level!
The ignition will automatically rise to the set position height: such a function is no matter what kind of height you park, such as the lowest or the highest, when you stop, get off, and drive again, the system will automatically raise the car to the second gear position, that is, the height of the normal car! This has both advantages and disadvantages. For example, the road condition is very bad. There is no suitable parking space. When parking, stop at the highest position. When you drive again, the system will automatically decrease. If you just stop at a very high rural cement deceleration belt, it is very likely to or directly support the bottom! The advantage is that in a normal parking lot, the parking car will be lowered to the lowest level. When driving again, the train will automatically rise to the normal driving height. Think about how high this force is
One button to the lowest: one button, you can reduce the car to the lowest state! There is a one button down button on the control panel. If you press and hold for 3 seconds, the whole car will be in the lowest state! Why three seconds? Because this is to prevent misoperation. If your car is running, if a child or some special situation accidentally touches the one button lowering button, it is a very terrible thing. In this way, this kind of design can completely avoid this kind of situation. It doesn't matter if you touch all the buttons carelessly, as long as you don't press it for a long time!
