查看: 716|回复: 0
起亚索兰托追求完美打造最美低姿态改装气动避震
发表于 2020-10-18 14:38:33 | 只看该作者 |只看大图 回帖奖励 |倒序浏览 |阅读模式
Kia Sorento pursues perfection to create the most beautiful low profile modified pneumatic shock absorber
索兰托是起亚推出的一款车。2002年初一款酷似奔驰M级的suv被披露。仅仅几个月之后,这款车就正式定名为索兰托(Sorento)并投入量产。大量欧洲风格的设计手法,使得索兰托丢失了自己本身所具有的特色。
Sorento is a car launched by Kia. At the beginning of 2002, a SUV similar to Mercedes Benz M-class was disclosed. Just a few months later, the car was officially named Sorento and went into mass production. A large number of European style design techniques make Sorento lose its own characteristics.
今天为大家带来的是改装了AIRBFT气动避震的起亚索兰托,动感时尚的车身在气动避震改装低姿态的衬托下显现的更加的完美!改装AIRBFT气动避震只是为了降低车身玩姿态吗?答案是否定的,因为气动避震玩的不单单是姿态,实用性也是很好的,随时可以升降的底盘高度,在路况不好的情况下可以适当的升高车身来增强通过性,高速行驶时可以适当的降低车身来减小风阻,是一款实用性很强的改装避震!
Today, we bring you Kia Sorento, which is refitted with airbft pneumatic shock absorber. The dynamic and fashionable body is more perfect under the background of low attitude of pneumatic shock absorber refitting! Is airbft pneumatic shock absorber modified only to reduce body posture? The answer is no, because pneumatic shock absorbers play not only posture, but also good practicability. When the chassis height can be raised or lowered at any time, the vehicle body can be properly raised to enhance the trafficability in case of bad road conditions, and the body can be appropriately reduced to reduce the wind resistance when driving at high speed. It is a practical refitted shock absorber!
