查看: 732|回复: 0
“豪华新境 唤醒出行灵感”宝马5系打造低姿态的美
发表于 2020-10-18 13:20:26 | 只看该作者 |只看大图 回帖奖励 |倒序浏览 |阅读模式
"Luxury new world awakens travel inspiration" BMW 5 Series creates low profile beauty
国产5系是一款高档轿车,现款五系诞生于2004年,宝马的五系无疑是汽车史上最为出色的系列之一,它最巅峰的时代应该是从第三代E34(1988-1996)时就开始了,如今的五系则是E34的第三代产品。2017年4月,全新一代宝马5系长轴版全球首发。
The domestic 5 series is a high-grade car. The current five series was born in 2004. BMW's five series is undoubtedly one of the best series in the history of automobile. Its peak era should have been from the third generation E34 (1988-1996), and the current five series is the third generation of E34. In April 2017, the new generation of BMW 5 series long axis version was launched in the world.
气动避震悬挂很多人都知道是通过空气压力来控制车身高低的一种悬挂,但是能够带来哪些效果呢?可能很多人就不知道了。宝马5系改装气动避震悬挂首先会有一个完美的低姿态,爽心悦目。其次能升能降会有一个很好的改装乐趣舒适性也会有一定的提升,质量现在也比较稳定, 看看宝马5系的改装效果具体怎样!
Many people know that pneumatic suspension is a kind of suspension which controls the height of vehicle body by air pressure, but what effect can it bring? Maybe a lot of people don't know. BMW 5 Series modified pneumatic suspension will first have a perfect low attitude, pleasant to the eye. Secondly, it will have a good refitting pleasure if it can be raised or lowered. The comfort will also be improved to a certain extent. The quality is relatively stable now. Let's see how the modification effect of BMW 5 series is!
喜欢玩改装避震系统的发烧友,空气避震是话题里面最贵的一款。
听起来非常方便,气动避震到底是什么原理呢?
Like to play with the modified shock absorber system enthusiasts, air shock is the most expensive topic.
This is a configuration that can control the height of the body, and it can be turned into a low lying car at any time, and it can also become a normal height.
It sounds very convenient. What is the principle of aerodynamic shock avoidance?
It is not easy to choose the appropriate aerodynamic shock proof, and the level of the aerodynamic shock avoidance is different. Brands are also diverse.
At present, there are two main types of pneumatic modes in the market, mechanical pneumatic shock avoidance and electronic pneumatic shock avoidance. Needless to say, the technical content is relatively high when you hear the two words of electronic.
In price, it is higher than mechanical pneumatic shock proof, but the stability is not so reliable as mechanical type.
Pneumatic shock proof is a more precise accessory, compared with the original factory shock proof is a day by day.
There is an elastic rubber airbag on the pneumatic shock proof. The air bag is actually a closed pressure cylinder, which is filled with inert gas and oil-gas mixture. The pressure in the cavity is several times higher than the atmospheric pressure or even dozens of times. Then, the cross-sectional area of the piston rod is smaller than the cross-sectional area of the piston to generate pressure difference and make the piston rod move.
Because the pneumatic shock proof is a relatively precise component, with the air tank device, it is not suitable for driving violently in the bumpy road.
It is easy to cause chronic air leakage, cause unstable air pressure, increase the temperature in the air tank, and the pneumatic regulation will lose accuracy.
