查看: 919|回复: 0
“魅力、刺激”丰田锐志改装低趴范气动避震
发表于 2020-10-17 15:57:42 | 只看该作者 |只看大图 回帖奖励 |倒序浏览 |阅读模式
"Charming, exciting" Toyoda is determined to refit low lying fan aerodynamic shock absorber
锐志(REIZ)是日本丰田MARK X车型国产后的名称,它于2005年10月在天津一汽丰田二厂与皇冠共线生产、共用底盘,配备与皇冠相同的六速手自一体变速器。它于2017年9月停产,共计生产528188辆。
MARK X国产后改名锐志(REIZ),它源于德语,是“魅力、刺激”的意思,是丰田对目标消费群体的总体特征的概念性描述。
Reiz is the name of Japanese Toyota mark X after it was made in China. In October 2005, Reiz was produced and shared chassis with crown in Tianjin FAW Toyota No.2 factory. It is equipped with the same six speed automatic manual transmission as crown. It stopped production in September 2017 with a total production of 528188 vehicles.
Mark X was renamed Reiz after it was made in China. It originated from German, which means "charm and stimulation". It is a conceptual description of Toyota's overall characteristics of target consumer groups.
相信大家看到过有车子停靠在停车场,而车身离地面十分接近,心里难免会充满好奇,车子是如何做到这么低的?今天Aribft气动避震就给不清楚的小伙伴简单解释一下,其实,原理就是车子改装了气动避震,能够自由升降车子的高度。下面就让我们一起欣赏一下丰田锐志改装气动避震后的低趴效果。
I believe that you have seen a car parked in a parking lot, and the body is very close to the ground. You will inevitably be full of curiosity. How can the car be so low? Today aribft pneumatic shock absorbers will give a brief explanation to the unclear partners. In fact, the principle is that the car is refitted with pneumatic shock absorbers, which can freely raise and lower the height of the car. Now let's enjoy the effect of Toyoda's refitting pneumatic shock absorber.
正所谓一低遮百丑
这几年HF改装火遍大街小巷
气动减震
也是一夜变身改装界网红
话说这是个什么东西呢?
它其实是一套可以控制气压
改变车身高低的装置
与传说中的主动车身控制系统(ABC)类似
不过它的工作介质是气体
一般来说就是下图所示的这么一套家伙事
其中包括弹性橡胶气囊减震器
气压控制系统、后备箱储气罐
及电子控制系统等
它其实和空气减震的原理与常见减震器
螺旋弹簧+减震筒形式
原理十分类似
只不过
通过改变气室体积(上下方向)
来调整车身离地距离并一定程度改变软硬特性
另外减震筒部分则可以由电机改变通气孔尺寸
从而调节减震器的衰减力
因此空气减震器往往
能提供更好的性能表现
嗯!就是这么自信
Pneumatic shock absorption
So what is this?
But its working medium is gas
And electronic control system
The principle is very similar
It's just
Yeah! So confident
