查看: 933|回复: 0
桑塔纳改装气动避震低趴案例欣赏
发表于 2020-10-16 15:58:33 | 只看该作者 |只看大图 回帖奖励 |倒序浏览 |阅读模式
桑塔纳改装气动避震低趴案例欣赏
Enjoy the case of Santana low vibration
大众桑塔纳(SANTANA)牌是一款轿车,是德国大众汽车公司在美国加利福尼亚州生产的品牌车,从1985年开始,经过20多年的生产历史,普通桑塔纳轿车的身影遍及全国。
The Santana brand of Volkswagen is a car, which is a brand car produced by German Volkswagen Company in California, USA. since 1985, after more than 20 years of production history, ordinary Santana cars are all over the country.
“开不坏的桑塔纳 ,修不好的切诺基。”一句老话说出桑塔纳在老一辈人心目中优秀的形象,全新桑塔纳 质量好不好,先看外观,新款桑塔纳的外观设计已经完全没有老款的影子,完美圆润,符合现在人的审美,今天来看新桑塔纳的气动避震低趴姿态。
"Good Santana, bad Cherokee." As an old saying goes, Santana has an excellent image in the minds of the older generation. Whether the quality of the new Santana is good or not depends on the appearance. The appearance design of the new Santana has no shadow of the old one. It is perfect and mellow, which is in line with people's aesthetic taste. Today, we can see the new Santana's low lying posture of aerodynamic shock absorption.
汽车避震是由弹簧和减震器共同组成的。
