查看: 728|回复: 0
奔驰两门couper气动避震改装低趴案例
发表于 2020-10-16 14:39:21 | 只看该作者 |只看大图 回帖奖励 |倒序浏览 |阅读模式
A case of refitting Mercedes Benz two door couper with aerodynamic shock absorber
奔驰两门Coupe作为全球最具吸引力的双门轿跑车,E级双门轿跑车自2009年登陆中国以来,便以无出其右的优雅气质和全球顶级的环保科技,成为众多精英人士梦寐以求的轿跑车。此次E 200双门轿跑车的引进,进一步扩充了 梅赛德斯 - 奔驰E级双门轿跑车的产品阵容,同时让更多自信、成功、个性鲜明精英人士更轻松的拥有这款梦想座驾。
As the most attractive coupe in the world, Mercedes Benz two door coupe has become the dream car of many elites with its unparalleled elegant temperament and the world's top environmental protection technology since it landed in China in 2009. The introduction of E200 coupe further expands the product lineup of Mercedes Benz E-class coupe, and makes it easier for more confident, successful and distinctive elites to own this dream car.
3: Every detail was checked. Every customer was responsible for the air leakage caused by the installation!
