查看: 703|回复: 0
创新激情永不灭优秀老奔驰改装气动避震尽显低姿态完美的身姿
发表于 2020-10-15 15:35:03 | 只看该作者 |只看大图 回帖奖励 |倒序浏览 |阅读模式
Innovation passion never dies out excellent old Mercedes Benz refitted aerodynamic shock absorber shows perfect posture with low posture
梅赛德斯-奔驰(Mercedes-Benz),德国豪华汽车品牌,汽车的发明者,被认为是世界上最成功的高档汽车品牌之一,其完美的技术水平、过硬的质量标准、推陈出新的创新能力,以及一系列经典轿跑车款式令人称道。奔驰三叉星已成为世界上最著名的汽车及品牌标志之一。
Mercedes Benz, the German luxury car brand and the inventor of automobile, is considered as one of the most successful high-end automobile brands in the world. Its perfect technical level, excellent quality standard, innovation ability and a series of classic coupe styles are praised. Benz Trident has become one of the most famous automobile and brand marks in the world.
提到奔驰很多人的评价基本上都是豪华、舒适。而随着奔驰家族AMG的面世,奔驰不再是人们眼里的豪华,转而也同运动搭上边。改装气动避震也就是让车身变得更低了,像这种改装后的车我们经常会在一些高档的地方见十分帅气,下面这辆奔驰就是改装的气动避震减振器
When it comes to Mercedes Benz, many people's comments are basically luxurious and comfortable. With the advent of AMG, Mercedes Benz is no longer a luxury in people's eyes, but also with sports. Refitting the pneumatic shock absorber is to make the body lower. We can often see it very handsome in some high-end places after refitting. This Mercedes Benz is the modified pneumatic shock absorber
