查看: 888|回复: 0
现代领动AIRBFT气动避震三段记忆手机蓝牙APP完工
发表于 2020-10-15 15:11:27 | 只看该作者 |只看大图 回帖奖励 |倒序浏览 |阅读模式
Modern leader airbft pneumatic shock absorber three segment memory phone Bluetooth app completed
2015广州车展正在火爆开展中,北京现代领动也正式发布,而早前的新朗动正式更名为领动,现代领动将有望明年3月开始量产并投放市场。早前的新朗动正式更名为领动,现代领动将有望明年3月开始量产并投放市场。
Guangzhou auto show 2015 is in the process of booming, and Beijing Hyundai Lingdong has also officially released its name, and the new Langdong has been officially renamed as Lingdong. Hyundai Lingdong is expected to start mass production and put into the market in March next year. The earlier new Langdong was officially renamed as Lingdong, and Hyundai Lingdong is expected to start mass production and put into the market in March next year.
现代朗动外观设计时尚潮流,受到年轻一代的青睐,它的同胞小弟现代领动的出现,自然不能落于下风, 经过气动避震的改装,将车子的底盘降到了最低,气质的提升立竿见影!!平民车玩改装也是很有意思,从此与众不同!这辆领动改装气动避震悬挂姿态依然不凡,魅力欣赏!
The appearance design fashion trend of modern Langdong is favored by the younger generation. The appearance of its younger brother, Hyundai leader, naturally can't fall behind. After the modification of pneumatic shock absorber, the chassis of the car is reduced to the lowest level, and the improvement of temperament is instant!! Civilian car play refit is also very interesting, from now on is different! This car is refitted with pneumatic shock absorber. Its posture is still extraordinary, and its charm is appreciated!
Let's break down the word hellaflush = Hella flush, that is, there are two parts, one is Hella, the other is flush. Hella is the abbreviation of "hell of", which means special, extraordinary, absolute and super; flush means flush. Therefore, two points should be understood here: 1. The formation of hellaflush must first satisfy the requirements of flush, that is, flat wheel tires, and then be qualified to make efforts from flush to hellaflush; 2. The body height must be as low as possible, and there must be no gap between the tire and the leaf plate from the side of the car.
