查看: 678|回复: 0
爱上就忘不掉奔驰E300改装气动避震低趴姿态不得了了
发表于 2020-10-15 14:50:03 | 只看该作者 |只看大图 回帖奖励 |倒序浏览 |阅读模式
Fall in love with Mercedes Benz E300 refit pneumatic shock absorber low prone posture is amazing
奔驰E300L是一款专为中国市场设计的专属座驾,其加长的轴距完全是为了满足国内用户的需求,其国产后将会提供比进口版本更具竞争力的售价。
尾部的标识是新车身份的证明,戴克分家之后,本国新一代E级车型尾部“北京奔驰-戴克”的标识变为了现在的“北京奔驰”。而E300L的标识则清晰地表明了,新车是一款加长车型。而车身其他的部分则与进口车型十分接近。
Mercedes Benz e300l is a special car specially designed for the Chinese market. Its extended wheelbase is entirely to meet the needs of domestic users. After being made in China, it will provide more competitive price than the imported version.
The logo on the tail is a proof of the identity of the new car. After the separation of dyke, the logo of "Beijing Benz dyke" at the rear of the new generation of E-class models in China has become the current "Beijing Benz". The e300l logo clearly shows that the new car is a longer model. The other parts of the body are very close to the imported models.
奔驰E300l 仔细一看不得了,还是在地上趴着呢!原来这辆E300l是在改装了气动避震套件,不仅能够玩低趴,还能提高驾驶的舒适度。四轮独立升降都不是梦!
Mercedes Benz e300l has a close look, or lying on the ground! It turns out that the e300l is refitted with pneumatic shock absorbers, which can not only play low lying down, but also improve driving comfort. Four independent lifts are not dreams!
