查看: 862|回复: 0
宝马F80改装气动避震 给您带来不一样的驾车感受
发表于 2020-10-15 14:29:04 | 只看该作者 |只看大图 回帖奖励 |倒序浏览 |阅读模式
The modified pneumatic shock absorber of BMW F80 brings you different driving experience
宝马一直是驾驶爱好者的偶像品牌,而对于那些狂热驾驶分子来说,宝马AF80算得上是偶像中的偶像。
BMW has always been the idol brand of driving enthusiasts, and for those crazy drivers, BMW af80 can be regarded as the idol among the idols.
新车均基于新打造,并加入了最新的F运动套件,同时还搭载了3.0T双涡轮增压发动机,上一代经典的V8自然吸气发动机将缺席,然而这款F80别出风格改装Airllen气动避震。上演低趴文化,给您带来不一样的驾车感受
The new cars are all based on new products, and the latest f sports kit is added. At the same time, it is equipped with a 3.0T twin turbocharged engine. The previous generation of classic V8 naturally aspirated engine will be absent. However, this F80 has a distinctive style and is refitted with airlen pneumatic shock absorber. The performance of low lying culture brings you different driving experience.
