查看: 738|回复: 0
十代思域AIRBFT气动避震套件三段记忆版本手机APP遥控
发表于 2020-10-14 15:45:59 | 只看该作者 |只看大图 回帖奖励 |倒序浏览 |阅读模式
Ten generations of civic airbft pneumatic shock absorber package three segment memory version of mobile phone app remote control
2016年4月12日,东风本田正式公布了新一代思域的售价,新思域是本田第十代Civic的国产版车型,采用了更加年轻运动化的设计,动力上将搭载1.5T和1.0T发动机,前期先推1.5T车型,搭载6速手动或者CVT变速箱。共推出四款车型,售价区间为12.99-16.99万元
Honda Civic has launched a variety of models to cater to the tastes of consumers in different countries, including three hatchback hatchback hatchback coupe, hybrid and five door RV. The Honda Civic and Dongfeng Honda's existing models, Honda CR-V, come from the same production platform. The two models use the same chassis, which provides technical preconditions for the domestic Honda Civic. After 40 years of experience and continuous evolution in 10 generations of deduction, today's 10th generation Civic (Civic) gathers many advanced technologies of leading times, presenting you with a charming work with a sense of future and science and technology.
On April 12, 2016, Dongfeng Honda officially announced the price of the new generation Civic. The new Civic is the domestic version of Honda's 10th generation Civic, which adopts a younger and more sporty design. The power will be equipped with 1.5T and 1.0T engines. In the early stage, it will launch a 1.5T model with a 6-speed manual or CVT transmission. A total of four models were launched, with a price range of 129900-169900 yuan
十代思域延续了思域系列的众多优点, 那么各方面都这么优秀的十代思域怎样才能避免成为街车呢?当然是追求HellaFlush改装风格了,简单的换个轮毂改个气动避震就能实现低趴范, 整车瞬间焕然一新,要改装一辆车首先你得了解这辆车, 改装界流行一句话叫"百改降为先“我再补充一句,低趴才是王道!任何的改装如果没有气动避震改装的话,我感觉就像行尸走肉,徒有一个光鲜的外表,没有灵魂!正所谓一低遮百丑,气动避震改装是提升整车气质最关键的一笔!
Ten generations of civic continued the many advantages of civic series, so how can we avoid becoming a streetcar? Of course, it's the pursuit of hellaflush refitting style. Simply changing the wheel hub and changing the pneumatic shock absorber can realize the low prone model, and the whole vehicle will take on a brand-new look. To refit a car, you must first understand the car. The popular saying in the refitting industry is "first of all changes". I'll add that low lying is the king's way! If there is no pneumatic shock absorber refitting, I feel like a walking corpse, with a bright appearance and no soul! The so-called ugliness is the key to improve the quality of the car!
喜欢玩改装避震系统的发烧友,空气避震是话题里面最贵的一款。
听起来非常方便,气动避震到底是什么原理呢?
