查看: 582|回复: 0
"引天下之事“奔驰W205改装AIRBFT气动避震的低趴案例
发表于 2020-10-14 14:22:08 | 只看该作者 |只看大图 回帖奖励 |倒序浏览 |阅读模式
"Leading the world" Mercedes Benz w205 refitting airbft pneumatic shock absorber
在这个时代想要引人注目,没有独特的改装是无法给人深刻的印象的。对于奔驰车的车主来说,仅仅将车作为代步工具的话只会显得自己的生活淡而无味,追求个性,享受驾车的愉悦才是奔驰应有的生活态度。
In this era, if you want to be conspicuous, you can't make a deep impression without a unique modification. For the owners of Mercedes Benz, if they only use the car as a means of transportation, their life will be dull. Pursuing individuality and enjoying the pleasure of driving are the proper life attitude of Benz.
