查看: 750|回复: 0
值得一改现代菲斯塔改装AIRBFT气动避震完工效果展示
发表于 2020-10-10 15:50:55 | 只看该作者 |只看大图 回帖奖励 |倒序浏览 |阅读模式
It's worth changing the modern festa and refitting airbft pneumatic shock absorber
现代菲斯塔外观设计时尚潮流,受到年轻一代的青睐, 自然不能落于下风,这辆菲斯塔改装气动避震悬挂姿态依然不凡,魅力欣赏!
改装气动避震悬挂,一套完美的轮毂数据是每个人都想要的,因为趴下来的效果好坏真的明显,现代菲斯塔 改装气动避震悬挂的完美姿态,让我们一起来欣赏它的魅力!
小改怡情,大改伤身。一入改装深似海,改车一时爽,一直改车一直爽,只是存款从此变路人。为什么要改车呢?只为了从众多普通车中一眼认出她,那独一无二的气质。
The appearance design of modern festa is fashionable and popular with the younger generation. Naturally, it can't fall behind. The modified pneumatic shock absorber suspension of this feista is still outstanding, and its charm is appreciated!
Refit pneumatic shock suspension, a set of perfect wheel hub data is what everyone wants, because the effect of lying down is really obvious. The perfect posture of modern festa refitting pneumatic shock suspension, let's enjoy its charm together!
A small change will make you happy, but a big change will hurt you. As soon as I went into the refit, it was like a sea. I was happy to change my car for a while, but my savings have changed from then on. Why change the car? In order to recognize her from many ordinary cars, that unique temperament.
喜欢玩改装避震系统的发烧友,空气避震是话题里面最贵的一款。
听起来非常方便,气动避震到底是什么原理呢?
