查看: 699|回复: 0
时代留下的回忆捷达MK2改装气动避震重现当年的美
发表于 2020-10-10 15:35:46 | 只看该作者 |只看大图 回帖奖励 |倒序浏览 |阅读模式
Memories left by the times: Jetta MK2 refitted pneumatic shock absorber reappears the beauty of that year
捷达有着不坏神车的美称,凭借品质深受全球消费者认可,而中国引进的第一款是捷达第二代,在当时对欧洲而言是已显得有些陈旧的两气门化油器轿车,即捷达CL。尽管如此,捷达CL面对中国市场,当时的技术、装备和设计工艺已算得上很优秀了,因为捷达在整体开发上已经领先中国同行业水平。捷达更新到第四代就是宝来 ,而在美国仍然被叫做捷达。
Jetta has the reputation of not bad God car. It is recognized by global consumers by its quality. The first model introduced by China is Jetta second generation. At that time, it was a two valve carburetor car, namely Jetta CL. Nevertheless, Jetta CL faced the Chinese market, and its technology, equipment and design process were excellent at that time, because Jetta had already been ahead of China's counterparts in overall development. The fourth generation of Jetta is Bora, which is still called Jetta in the United States.
说到捷达MK2,大家肯定都是耳熟能详。这款车型在中国已经卖了二十几年,优秀的底盘可靠的发动机,在国人看来捷达的口碑那必然是响当当的。虽然属于老三样的捷 达,在今天众多的车型中算是没有什么新鲜感了。在大街上真是随处可见,但是你想看见一辆改装的很有味道的捷达,恐怕是件不容易的事情,可不管是国内还是国外,捷达MK2的修复改装案例都很多,那么接下来的捷达改装,肯定会让你眼前一亮。
When it comes to Jetta MK2, everyone must be familiar with it. This model has been sold in China for more than 20 years. With excellent chassis and reliable engine, Jetta's reputation in China must be well known. Although it belongs to the old three kinds of Jetta, there is nothing new in today's numerous models. It can be seen everywhere on the street, but it's not easy for you to see a Jetta which has been refitted with flavor. However, no matter at home or abroad, there are many cases of repairing and refitting the Jetta MK2, so the following Jetta refitting will surely make your eyes shine.
