查看: 828|回复: 0
丰田皇冠改装气动避震展示最极致的低趴美学
发表于 2020-10-10 15:18:01 | 只看该作者 |只看大图 回帖奖励 |倒序浏览 |阅读模式
Toyota Crown refitting pneumatic shock absorber shows the most extreme low lying Aesthetics
Crown is a large and medium-sized car brand of Toyota group. Toyota Crown was launched in Japan on January 1, 1955. There are more than the 13th generation models. The domestic crown engines are 2.5L, 3.0L and 4.3L. The first two engines are V6 cylinder 24 valve design, and the 4.3L engine is V-type eight cylinder. Dual VVT-i intelligent timing variable system of inlet and outlet valves is configured.
The intake efficiency, fuel economy and power performance of the engine are greatly improved, and the horsepower is more powerful. In terms of chassis, it adopts four-wheel fully independent suspension, which is very comfortable.
沿袭气动避震改装Hellaflush风格动感时尚的低趴改装理念,丰田皇冠采用AIRBFT气动避震控制系统,量身定制的全新高压橡胶气囊与控制系统相得益彰,打造了最完美的低趴姿态,使得车身更具感染力、更富有运动感,同时不失时尚优雅的气息。同时,极致的低趴姿态与完美的高抛亮轮毂相呼应,营造出丰田皇冠极具运动感车身整体的低趴效果。
Following the dynamic and fashionable low lying refitting concept of hellaflush style pneumatic shock absorber refitting, Toyota Crown adopts airbft pneumatic shock absorber control system, and the customized new high-pressure rubber airbag and control system complement each other to create the most perfect low prone posture, making the body more dye-resistant, more sporty and fashionable. At the same time, the extreme low prone posture and the perfect high polished wheel hub echo, creating the Toyota Crown very sporty body overall low prone effect.
Let's break down the word hellaflush = Hella flush, that is, there are two parts, one is Hella, the other is flush. Hella is the abbreviation of "hell of", which means special, extraordinary, absolute and super; flush means flush. Therefore, two points should be understood here: 1. The formation of hellaflush must first satisfy the requirements of flush, that is, flat wheel tires, and then be qualified to make efforts from flush to hellaflush; 2. The body height must be as low as possible, and there must be no gap between the tire and the leaf plate from the side of the car.
