查看: 622|回复: 0
强势气场巨有范奔驰W205改装AIRBFT气动避震的低趴案例
发表于 2020-10-10 15:00:12 | 只看该作者 |只看大图 回帖奖励 |倒序浏览 |阅读模式
Strong gas field: a case study of refitting w205 Mercedes Benz w205 into airbft pneumatic shock absorber
在这个时代想要引人注目,没有独特的改装是无法给人深刻的印象的。对于奔驰W轿车的车主来说,仅仅将作为代步工具的话只会显得自己的生活淡而无味,追求个性,享受驾车的愉悦才是奔驰W205应有的生活态度。
In this era, if you want to be conspicuous, you can't make a deep impression without a unique modification. For the owners of Mercedes Benz w car, if they only use it as a vehicle, their life will be dull and tasteless. Pursuing individuality and enjoying the pleasure of driving are the proper life attitude of Benz w205.
