查看: 670|回复: 0
C位当然不让九代思域改装气动避震低趴风依旧白看不腻
发表于 2020-10-8 15:58:24 | 只看该作者 |只看大图 回帖奖励 |倒序浏览 |阅读模式
C position certainly does not let nine generation Civic refit aerodynamic shock absorption, low lying wind still white look not tired
东风本田全新第九代CIVIC(思域)9月16日在成都车展正式发布,六款车型分别包括1.8L的四款和2.0L的两款,其中1.8L车型设置为EXi MT舒适型手动挡、EXi AT舒适型自动挡、VTi AT豪华型自动挡、VTi AT NAVI豪华自动导航版。
Dongfeng Honda's new ninth generation Civic (Civic) was officially released at Chengdu auto show on September 16. Six models include four models of 1.8L and two models of 2.0L. Among them, the 1.8L model is set as exi MT comfortable manual transmission, exi at comfortable automatic transmission, VTI at luxury automatic transmission and VTI at Navi luxury automatic navigation version.
气动避震是利用空气压力来调整车身高低。由绞牙避震筒身,高压橡胶气囊,控制系统,打气泵,储气罐等组成。可以用来快速升降车身、范围达100-150mm根据车型而定!今天介绍的这台本田第九代思域就是通过改装气动避震来实现降低车身姿态的目的,爱改装的车友都知道一低遮百丑,一台车子总体气质的体现,降低车身是最关键的一笔!
Low air pressure is used to adjust the height of the car. It is composed of hinge tooth shock absorber body, high pressure rubber air bag, control system, air pump, air storage tank, etc. Can be used to quickly lift the body, range up to 100-150 mm, depending on the model! The ninth generation Civic of Honda introduced today is to reduce the body posture by refitting the pneumatic shock absorber. All the car friends who love to refit all know that a low cover for hundreds of ugliness is the embodiment of the overall temperament of a car. Reducing the body is the most important thing!
喜欢玩改装避震系统的发烧友,空气避震是话题里面最贵的一款。
听起来非常方便,气动避震到底是什么原理呢?
