查看: 808|回复: 0
“来源于古罗马的女神Fides”大众辉昂改装气动避震蜕变从低趴开始
发表于 2020-10-8 15:35:52 | 只看该作者 |只看大图 回帖奖励 |倒序浏览 |阅读模式
"Maides from ancient Rome" Volkswagen huiang refitted pneumatic shock absorber transformation starts from low lying down
在2016日内瓦车展中,大众发布了旗下全新中大型轿车——PHIDEON,新车采用和奥迪A6相同的MLB平台打造,并将率先由上汽大众引入国内生产并销售。而在2016北京车展前的大众之夜上,上汽大众PHIDEON于中国正式首发,中文正式定名为"辉昂"。
PHIDEON的名称来源于古罗马的女神“Fides”,象征誓约与信仰,PHIDEON将是大众的首款中大型车,将衔接辉腾与迈腾之间的市场空白。
由于辉昂英文名Phideon的发音与象征着誓约、忠诚与信仰的罗马女神—菲得斯FIDES发音接近,因此该车的名字意味着优雅和可靠。
At the 2016 Geneva auto show, VW released its new medium and large-scale sedan, phieon. The new car was built on the same MLB platform as Audi A6, and SAIC Volkswagen will be the first to introduce it into domestic production and sales. On the public night before the 2016 Beijing auto show, SAIC Volkswagen phideon was officially launched in China and officially named "huiang" in Chinese. [1]
The name of phideon comes from the goddess "fides" of ancient Rome, symbolizing vows and beliefs. Phideon will be the first medium and large-scale car of the public, which will link up the market gap between Huiteng and maiteng.
Because the pronunciation of phideon is similar to that of fides, the Roman goddess who symbolizes vows, loyalty and faith, the name of the car means elegance and reliability.
不管从什么时候开始,重要的是开始以后不要停止;不管在什么时候结束,重要的是结束以后不要后悔。HellaFlush已经成为了一个国际化的改车潮流,跟随着时代的步伐也越来越流行,,越来越被大众喜欢,无论什么类型的车种都可以驾驭,HellaFlush已经趋向为一种品味的认证。所以,一起向HellaFlush看齐吧!
No matter when you start, it's important not to stop after you start; no matter when you end, it's important not to regret after the end. Hellaflush has become an international trend of changing cars. With the pace of the times, it is becoming more and more popular. It is more and more popular among the public. No matter what type of car can be driven, hellaflush has become a taste certification. So, let's look at Hella flush!
正所谓一低遮百丑
这几年HF改装火遍大街小巷
气动减震
也是一夜变身改装界网红
话说这是个什么东西呢?
它其实是一套可以控制气压
改变车身高低的装置
与传说中的主动车身控制系统(ABC)类似
不过它的工作介质是气体
一般来说就是下图所示的这么一套家伙事
其中包括弹性橡胶气囊减震器
气压控制系统、后备箱储气罐
及电子控制系统等
它其实和空气减震的原理与常见减震器
螺旋弹簧+减震筒形式
原理十分类似
只不过
通过改变气室体积(上下方向)
来调整车身离地距离并一定程度改变软硬特性
另外减震筒部分则可以由电机改变通气孔尺寸
从而调节减震器的衰减力
因此空气减震器往往
能提供更好的性能表现
嗯!就是这么自信
Pneumatic shock absorption
So what is this?
But its working medium is gas
And electronic control system
The principle is very similar
It's just
Yeah! So confident
