查看: 809|回复: 0
宝马5系G38气动避震低姿态魅力改装案例
发表于 2020-10-8 14:46:48 | 只看该作者 |只看大图 回帖奖励 |倒序浏览 |阅读模式
BMW 5 series g38 aerodynamic shock absorber low profile charm refitting case
万变不离其宗,改装最佳的选择还是外观姿态,改装车与我们的生活联系越来越紧密。各种车型的改装案例在我们的生活中都能见到,一些经典老车或是新款的车型都有不同的群体玩家,今天我们就来看看最新款宝马5系改装AIRBFT气动避震悬挂拥有怎么的姿态效果!
The best choice for refitting is the appearance and posture. Refitting cars are more and more closely related to our life. The refitting cases of various models can be seen in our life. Some classic old cars or new models have different groups of players. Today, let's take a look at the posture effect of the latest BMW 5 Series Modified airbft pneumatic suspension!
全新BMW 5系目前已是第七代车型,铝合金和超高强度钢材的广泛应用让新一代车型整车减重最多达130kg,提升车身刚性的同时,一定程度上也提升了操控性。
The new BMW 5 series is now the seventh generation model. The wide application of aluminum alloy and ultra-high strength steel has reduced the weight of the new generation of vehicle by up to 130kg, which improves the rigidity of the body and improves the handling ability to a certain extent.
