查看: 1021|回复: 0
凯迪拉克XT4,XT5双子星三段记忆AIRBFT气动避震气动底盘升降模式
发表于 2020-10-7 15:40:23 | 只看该作者 |只看大图 回帖奖励 |倒序浏览 |阅读模式
Cadillac xt4, xt5 Gemini three segment memory airbft pneumatic shock absorber pneumatic chassis lifting mode
XT4,XT5延续凯迪拉克“艺术与科技”的设计理念 ,通过短车头长车身的设计带来更宽适的车内空间表现。同时将跑车化的动感流线设计和大倾角挡风玻璃融入其中。XT5车身高长比值达到了同级最低的0.35,在运动的外形下带来更好的风阻和降噪表现,充分体现了SUV运动化趋势下纤长流线型的设计风格。让我们来欣赏一下凯迪拉克XT4,XT5改装气动避震悬挂的魅力低姿态!
Xt4, xt5 continue Cadillac's "art and technology" design concept, through the design of short front and long body, it brings wider and more suitable interior space performance. At the same time, the dynamic streamline design of sports car and large angle windshield are integrated into it. The ratio of height to length of xt5 body reaches the lowest of 0.35 in the same level, which brings better performance of wind resistance and noise reduction under the moving shape, which fully reflects the design style of fiber long flow line under the trend of SUV sports. Let's enjoy the charming low posture of Cadillac xt4, xt5 refitted pneumatic suspension!
喜欢玩改装避震系统的发烧友,空气避震是话题里面最贵的一款。
听起来非常方便,气动避震到底是什么原理呢?
