查看: 620|回复: 0
大众凌渡改装气动避震气场颜值飙升杠杠的
发表于 2020-10-7 15:10:58 | 只看该作者 |只看大图 回帖奖励 |倒序浏览 |阅读模式
大众凌渡改装气动避震气场颜值飙升杠杠的
Volkswagen lingdu refitting pneumatic shock absorber
据介绍,“凌渡”二字取意于“凌风渡越”,英文名“Lamando”源于西班牙语中的“Mandar”,意为“指挥、管理、引领与启示”。
凌渡(Lamando)是上汽大众2014年8月在成都车展推出的一款紧凑型新车。
上汽大众将凌渡定义为“首款宽体轿跑车”,其基于MQB平台打造,搭载EA888 TSI、EA211 TSI发动机,采用湿式7速双离合变速器。主打高端,属运动型紧凑车,定位于朗逸和帕萨特之间。
According to reports, the word "lingdu" takes the meaning of "lingfengdu", and the English name "lamando" comes from "mandar" in Spanish, meaning "command, management, guidance and Enlightenment".
Lamando is a new compact car launched by SAIC Volkswagen in Chengdu auto show in August 2014.
SAIC Volkswagen defines lingdu as "the first wide body coupe", which is built on the MQB platform, equipped with EA888 TSI and ea211 TSI engines, and adopts a wet 7-speed dual clutch transmission. It mainly focuses on high-end, and is a sports compact car, which is positioned between Langyi and Passat.
大众凌度是比较年轻时尚的车型,下面的这台改装气动避震的大众凌度更是将时尚进行到了极致!
在气动避震的作用下来降低车身,完成了外观的蜕变,真心是让人眼前一亮!年轻人,就得多做爱~做的事!
Volkswagen lingdu is a relatively young and fashionable model, and the Volkswagen lingdu refitted with pneumatic shock absorber is the ultimate fashion!
In the role of pneumatic shock absorber to lower the body, complete the transformation of the appearance, really let people see! Young people, you have to do more sex!
正所谓一低遮百丑
这几年HF改装火遍大街小巷
气动减震
也是一夜变身改装界网红
话说这是个什么东西呢?
它其实是一套可以控制气压
改变车身高低的装置
与传说中的主动车身控制系统(ABC)类似
不过它的工作介质是气体
一般来说就是下图所示的这么一套家伙事
其中包括弹性橡胶气囊减震器
气压控制系统、后备箱储气罐
及电子控制系统等
它其实和空气减震的原理与常见减震器
螺旋弹簧+减震筒形式
原理十分类似
只不过
通过改变气室体积(上下方向)
来调整车身离地距离并一定程度改变软硬特性
另外减震筒部分则可以由电机改变通气孔尺寸
从而调节减震器的衰减力
因此空气减震器往往
能提供更好的性能表现
嗯!就是这么自信
Pneumatic shock absorption
So what is this?
But its working medium is gas
And electronic control system
The principle is very similar
It's just
Yeah! So confident
