查看: 604|回复: 0
铝合金精抛三加仑鱼雷气罐到货整体旋压成型,拒绝焊接气孔漏气
发表于 2020-10-6 16:18:13 | 只看该作者 |只看大图 回帖奖励 |倒序浏览 |阅读模式
Aluminum alloy fine polishing three gallon torpedo gas tank is formed by spinning as a whole, and air leakage is not allowed in welding holes
