查看: 533|回复: 0
大众新CC改装AIRBFT气动避震的低趴魅力
发表于 2020-10-6 15:57:12 | 只看该作者 |只看大图 回帖奖励 |倒序浏览 |阅读模式
Low lying charm of aerodynamic shock absorbers refitted by Volkswagen's new CC
一汽-大众CC无疑是2010年中国高级轿车新车榜里的一匹黑马,改写了国产高级轿车中庸刻板的特性。
被誉为“最美大众汽车”的一汽-大众CC在设计、用料和做工上下足了功夫,TSI+DSG动力总成、丹拿音箱以及超前的智能化配备,都给人带来更高端的用车感受。
大众汽车设计师罗西蒙曾说道:“理想的汽车是高效率的,动感十足而具有责任的。对于大众来说,设计是基本的元素,大众公司并不强调更多花哨的内容,不是花哨噱头的设计,而强调一种非常坚实的简约,是一种非常纯粹的设计,这种纯粹和简约能够让消费者更好地认识理解和接受。”
一汽-大众CC的设计师Oliver Stefanni曾说:“CC所有的设计元素都从豪华车中提取,放大并超越,达到其他车型所无法企及的境界……”成熟大气的外观设计、高档品质的内饰档次,呈现了跑车风格与豪华轿车的舒适,众多人性化的设计令CC跻身豪华运动型轿车前列。精雕细琢的工艺水平,精益求精的细节设计,体现出一汽-大众对于完美的不懈追求
FAW-VW CC is undoubtedly a black horse in the list of new luxury cars in China in 2010, which rewrites the mediocre and rigid characteristics of domestic luxury cars.
FAW Volkswagen CC, known as the "most beautiful Volkswagen", has made great efforts in design, materials and workmanship. TSI + DSG powertrain, Dana speaker and advanced intelligent equipment all bring more high-end car feeling.
"The ideal car is efficient, dynamic and responsible," Volkswagen designer rosemon once said. For the public, design is the basic element. Volkswagen does not emphasize more fancy content, not fancy design, but emphasizes a very solid simplicity, which is a very pure design. This kind of purity and simplicity can make consumers better understand and accept it. "
Oliver stefanni, the designer of FAW Volkswagen CC, once said: "all the design elements of CC are extracted from luxury cars, amplified and surpassed to reach a level that other models can't reach..." The mature and atmospheric exterior design and high-grade interior quality show the style of sports car and the comfort of luxury car. Many humanized designs make CC rank in the forefront of luxury sports cars. The exquisite craftsmanship level and the meticulous design reflect FAW Volkswagen's unremitting pursuit of perfection
大众CC在国内非常受欢迎,作为一款专为年轻人打造轿跑车型,大众CC的设计确实抓住了年轻人的心,修长的车身,个性犀利的大灯设计,每一个细节都展现了年轻张扬的个性,最新款大众CC全新改款,有了很大的改变,依然很受年轻人喜欢,看看大众CC改装AIRBFT气动避震的低趴魅力!
Volkswagen CC is very popular in China. As a sedan car specially designed for young people, VW CC's design really catches the hearts of young people. Its slim body and sharp headlight design show the young and publicized personality in every detail. The latest VW CC has changed a lot and is still very popular with young people. Let's have a look at the modified airbft of VW CC Low lying charm of dynamic shock absorber!
喜欢玩改装避震系统的发烧友,空气避震是话题里面最贵的一款。
听起来非常方便,气动避震到底是什么原理呢?
