查看: 937|回复: 0
卡罗拉改装AIRBFT气囊减震器可以自由升降车身高度!
发表于 2020-10-4 15:33:53 | 只看该作者 |只看大图 回帖奖励 |倒序浏览 |阅读模式
Karola modified airbft airbag shock absorber can freely lift the body height!
卡罗拉(Corolla),曾用译名“花冠”,是丰田汽车的一个品牌。卡罗拉采用的是米其林轮胎215/45 R17轮胎、TRD Sportivo高性能减震器、TRD TF4 17寸运动型轮毂、强化离合器、高性能刹车片则保证其拥有比较理想的运动性能。
第一代卡罗拉于1966年发布,当时作为一款国民车推出,由于价格低廉,受到了当时消费者的热捧,到如今已经发展到了第11代,卡罗拉依然是全球最畅销的车型之一。
Corolla, once translated as corolla, is a brand of Toyota. Corolla uses Michelin tire 215 / 45 R17 tire, TRD Sportivo high-performance shock absorber, TRD tf4 17 inch sports wheel hub, reinforced clutch and high-performance brake pad, which ensure its relatively ideal sports performance.
The first generation of corolla was released in 1966, when it was launched as a national car. Due to its low price, it was warmly welcomed by consumers at that time. Up to now, it has developed to the 11th generation, and the Corolla is still one of the best-selling models in the world.
正所谓,人靠衣装,马靠鞍,车也不例外,最能凸显车主个性的当属外观上的改装。 分享改装里面的学问时就提到了外观改装,小车车顿时就涨知识了呢。今天,大家也跟着小车车一起来看看汽车外观改装避震,一起看看那些追随者们追寻的所谓改装文化。
As the saying goes, people rely on clothes, horses rely on saddles, and cars are no exception. The most prominent feature of owners' personalities is the appearance modification. When sharing the knowledge of refitting, I mentioned the appearance modification, and the knowledge of the car suddenly increased. Today, we are also following the car to see the appearance of the car, refit the shock absorber, and look at the so-called refitting culture pursued by those followers
喜欢玩改装避震系统的发烧友,空气避震是话题里面最贵的一款。
听起来非常方便,气动避震到底是什么原理呢?
