查看: 617|回复: 0
福特野马改装AIRBFT气动避震悬挂 低姿态风格
发表于 2020-10-4 15:15:10 | 只看该作者 |只看大图 回帖奖励 |倒序浏览 |阅读模式
Ford Mustang modified airbft pneumatic shock suspension low attitude style
新款野马以全新的完全现代化的车身结构和汽车底盘系统为基础,采用了先进的麦弗逊式支柱悬架和三连杆式驱动桥,带横向定位杆,总体平顺性达到了前所未有的高水平。就像一匹驰骋在广袤的草原上的骏马一样,野马始终散发着动力与速度的无穷魅力。2005款野马正是从受到极度好评的2003款概念车那里继承了简洁、时尚的设计传统。
The new Mustang is based on a completely new and completely modern body structure and chassis system. It adopts advanced McPherson strut suspension and three link drive axle, with lateral positioning bar. The overall ride comfort has reached an unprecedented high level. Like a horse galloping on the vast grassland, the wild horse always exudes the infinite charm of power and speed. The 2005 Mustang inherits the simple and fashionable design tradition from the 2003 concept car which is highly praised.
现在在路上我们会经常见到一些车子降的很低来开,看起来效果很不错,这种效果都是改装了气动避震悬挂。气动避震和原车空气悬挂是由一些区别的,主要是针对的使用效果不同。气动避震主要就是玩低趴,追求姿态的魅力!是年轻人喜欢的风格。今天给大家分享福特野马改装AIRBFT气动避震悬挂的魅力!
Now on the road, we often see some cars driving very low, it seems that the effect is very good, this effect is modified pneumatic shock absorber suspension. There are some differences between pneumatic shock absorber and original vehicle air suspension, mainly aiming at different application effects. Pneumatic shock absorption is mainly to play low lying down and pursue the charm of posture! It's the style that young people like. Today, I'd like to share with you the charm of modified airbft pneumatic suspension for Ford Mustang!
