查看: 654|回复: 0
标致408改装AIRBFT气动减震流行的改装风格
发表于 2020-9-30 16:43:39 | 只看该作者 |只看大图 回帖奖励 |倒序浏览 |阅读模式
Peugeot 408 modified airbft pneumatic shock absorption popular modification style
标致408是东风标致于2010年1月25日推出的一款紧凑车型,采用神龙公司主流的发动机,在排量上将有2.0L和1.6L两个选择。标致408的上市,极大地丰富了东风标致在1.6L-2.0L黄金排量市场的产品线。
Peugeot 408 is a compact model launched by Dongfeng Peugeot on January 25, 2010. It adopts the mainstream engine of DPCA and has two choices of 2.0L and 1.6L displacement. The listing of Peugeot 408 has greatly enriched Dongfeng Peugeot's product line in the 1.6l-2.0l gold displacement market.
减震器的工作原理主要用来抑制弹簧吸震后反弹时的震荡及来自路面的冲击。在经过不平路面时,虽然吸震弹簧可以过滤路面的震动,但弹簧自身还会有往复运动,而减震器就是用来抑制这种弹簧跳跃的。减震器的种类从产生阻尼材料的角度划分,减震器主要有液压和充气两种。
The working principle of the shock absorber is mainly used to suppress the shock of spring rebound and the impact from the road. Although the shock absorption spring can filter the vibration of the road surface when passing through the uneven road surface, the spring itself will have reciprocating motion, and the shock absorber is used to restrain the spring jumping. The types of shock absorbers are divided from the angle of producing damping materials. There are mainly two kinds of shock absorbers: hydraulic and pneumatic.
