查看: 763|回复: 0
充满活力、注重格调且富有进取精神的奥迪A3改装气动避震完美变身
发表于 2020-9-30 16:05:42 | 只看该作者 |只看大图 回帖奖励 |倒序浏览 |阅读模式
Full of vitality, style and enterprising spirit, Audi A3 refitted pneumatic shock absorbers perfect transformation
奥迪A3是奥迪出品的一款轿车产品,基于大众MQB平台研发,车身采用轻量化设计和铝制材料,动力上搭载1.4TFSI和1.8TFSI等多款发动机。
奥迪A3底盘前悬架为麦弗逊式,后桥为扭转、曲柄式结构带分开布置的弹簧和减振器,除了操纵性极佳外,后悬架布置的空间利用率也很高,因此载货面积在同级车中出类拔萃。所有A3系列车型,前后制动均为盘式,前制动带通风槽。
Audi A3 is a car product produced by Audi. It is developed based on the MQB platform of Volkswagen. Its body is made of lightweight design and aluminum material. It is equipped with 1.4tfsi and 1.8tfsi engines.
The front suspension of Audi A3 chassis is McPherson type, and the rear axle is of torsion and crank structure with separate springs and shock absorbers. In addition to excellent maneuverability, the space utilization rate of rear suspension layout is also very high, so the loading area is outstanding among the same class of vehicles. For all A3 series models, the front and rear brakes are disc type, and the front brake is equipped with ventilation groove.
汽车改装属于后市场的一种产物,许多车型因为原厂的设计比较平庸,不能满足玩家的要求,因此就出现了改装行业的繁荣现象,气动避震悬挂的改装属于一种外观的姿态改装,以贴地的美感博的玩家们的好感,视觉的强烈冲击和反常规状态引起强烈的共鸣,一起来欣赏 奥迪A3 改装案例|气动避震悬挂改装姿态的极致升华。
Car refitting is a product of the post market. Many models can not meet the requirements of the players because of the mediocre design of the original factory. Therefore, there is a prosperous phenomenon in the refitting industry. The refitting of pneumatic shock absorber suspension belongs to a kind of posture modification of appearance. The good feeling of the players, the strong visual impact and the unconventional state cause strong resonance together Let's enjoy the Audi A3 modification case | the ultimate sublimation of the modified attitude of pneumatic shock absorber suspension.
喜欢玩改装避震系统的发烧友,空气避震是话题里面最贵的一款。这是可以控制车身高度高低的配置,随时变成低趴车,也能变成正常的高度。听起来非常方便,气动避震到底是什么原理呢?
要选择合适的气动避震并不简单,气动避震的等级不同。品牌也是五花八门。目前市场上主要分两种气动方式,机械式气动避震和电子式气动避震,不用明说,光听见电子这两个字,就知道技术含量比较高。价格上,比机械式气动避震要高,但是稳定性上没有机械式这么可靠。气动避震是一件比较精密的配件,和原厂避震相比完全是一个天一个地。气动避震上各有一个弹性橡胶气囊,气囊其实是一个密闭的压力缸,里面充满了惰性气体和油气混合物。腔体内的压力要比大气压高几倍甚至几十倍左右,再利用活塞杆的横截面积小于活塞的横截面积,来产生压力差,使活塞杆运动。因为气动避震是比较精密的部件,有气罐装置,不适合在颠簸路段进行剧烈的驾驶。容易导致慢性漏气,引起气压不稳定,气罐内的温度会升高,气动调节就会失去精准度。
Like to play modified shock absorber system enthusiasts, air shock absorber is one of the most expensive topics. This is a configuration that can control the height of the body. It can become a low prone car at any time, and can also become a normal height. It sounds very convenient. What is the principle of pneumatic shock absorption?
It's not easy to choose the right pneumatic shock absorber. The grades of pneumatic shock absorbers are different. There are also various brands. At present, there are mainly two kinds of pneumatic shock absorbers in the market, mechanical pneumatic shock absorbers and electronic pneumatic shock absorbers. Needless to say, just hearing the word "electronic", you will know that the technical content is relatively high. The price is higher than the mechanical pneumatic shock absorber, but the stability is not as reliable as the mechanical type. Pneumatic shock absorber is a more precise accessory, compared with the original shock absorber, it is completely one day a place. There is an elastic rubber air bag on the pneumatic shock absorber. The air bag is actually a closed pressure cylinder filled with inert gas and oil-gas mixture. The pressure in the chamber is several times or even dozens of times higher than that of atmospheric pressure, and then the cross-sectional area of the piston rod is smaller than that of the piston to generate pressure difference and make the piston rod move. Because the pneumatic shock absorber is a more precise part and has an air tank device, it is not suitable for severe driving on bumpy roads. It is easy to cause chronic air leakage and unstable air pressure. The temperature in the air tank will rise, and the accuracy of pneumatic regulation will be lost.
