查看: 711|回复: 0
“最美汽车”猎豹XE捷豹XE改装气动避震低姿态完美落地
发表于 2020-9-29 16:32:18 | 只看该作者 |只看大图 回帖奖励 |倒序浏览 |阅读模式
"The most beautiful car" cheetah Xe, Jaguar Xe refitted pneumatic shock absorber, low attitude and perfect landing
捷豹XE是由捷豹自主研发生产的全新中型豪华运动轿车。捷豹XE采用了一系列在该细分市场中首次运用的捷豹顶级创新科技,包括全新的Ingenium发动机系列,以及其轻量化架构和成熟的底盘技术等 。
捷豹全新中级车XE将于2015年年中正式登场,这款全新车型被捷豹寄予厚望。日前,该车的具体动力信息得到确认,除了引入新一代的2.0T四缸发动机,它还将引入F-Type跑车上的两款3.0T V6机械增压发动机。
The Jaguar Xe is a new medium-sized luxury sports car independently developed and produced by Jaguar. The Jaguar Xe adopts a series of top-notch innovative technologies for the first time in this segment, including the new Ingenium engine family, its lightweight architecture and mature chassis technology.
Jaguar's new mid-range Xe will be officially launched in mid-2015, and this brand-new model is highly expected by Jaguar. Recently, the specific power information of the car has been confirmed. In addition to introducing a new generation of 2.0T four cylinder engine, it will also introduce two 3.0T V6 supercharged engines on the F-type sports car.
捷豹XE是迄今为止最先进、高效和精致的运动轿跑,延续了纯正的捷豹血统,全新捷豹XE是首款基于捷豹领先的智能全铝架构而研发的车型,有性能有外观,改装气动避震无疑是个不错的选择,这台捷豹XE改装气动避震悬挂,骚动姿态,完美低趴!
The Jaguar Xe is the most advanced, efficient and exquisite sports sedan so far, which continues the pure Jaguar pedigree. The all-new Jaguar Xe is the first car developed based on the intelligent all aluminum architecture of Jaguars. It has performance and appearance. It is undoubtedly a good choice to refit the pneumatic shock absorber. This Jaguar Xe refits the pneumatic shock suspension, which makes it tumultuous and perfectly low lying down!
