查看: 621|回复: 0
奔驰W205改装气动避震降低车身玩姿态
发表于 2020-9-29 15:13:06 | 只看该作者 |只看大图 回帖奖励 |倒序浏览 |阅读模式
奔驰W205改装气动避震降低车身玩姿态
Refitting Benz w205 with pneumatic shock absorber to reduce body posture
在这个时代想要引人注目,没有独特的改装是无法给人深刻的印象的。对于奔驰W205车的车主来说,仅仅将作为代步工具的话只会显得自己的生活淡而无味,追求个性,改装气动避震是为了玩低姿态和体验底盘升降的乐趣,能升能降绝对的高逼格利器, 改装气动避震悬挂完美演绎Hellaflush风格魅力!
In this era, if you want to be conspicuous, you can't make a deep impression without a unique modification. For the owners of Mercedes Benz w205, if they only use it as a walking tool, their life will be dull and pursuit of individuality. The purpose of refitting pneumatic shock absorber is to play a low posture and experience the fun of chassis lifting and lowering. It can lift and drop absolutely high-pressure sharp tools, and refit pneumatic shock absorber suspension perfectly deduce the charm of hellaflush style!
HellaFlush已经成为了一个国际化的改装车的外观潮流,越来越流行,越来越被大众所接受,无论类型车种贫富贵贱,无论随着国内改装车的发展与进步,越来越多的被大众所接受,HF范儿也成为了一种品位的象征,HellaFlush已经趋向为一种品味的认证。所以,一起加入这个运动吧!
Hellaflush has become an international appearance trend of refitted cars. It is more and more popular and accepted by the public. No matter what type of car is, whether rich or poor, whether with the development and progress of domestic modified cars, more and more people are accepted by the public. HF model has also become a symbol of taste. Hellaflush has become a taste certification. So, join the movement!
