查看: 784|回复: 0
奥迪敞篷A3AIRBFT桶身姿态完美升的高降的低太帅了
发表于 2020-9-29 14:41:17 | 只看该作者 |只看大图 回帖奖励 |倒序浏览 |阅读模式
The perfect low profile of Audi's aift
奥迪A3是奥迪出品的一款轿车产品,基于大众MQB平台研发,车身采用轻量化设计和铝制材料,动力上搭载1.4TFSI和1.8TFSI等多款发动机。
于A3三厢版车型打造,新车将极有可能采用折叠软篷设计。这款全新敞篷车未来将以宝马2系敞篷版车型为主要竞争对手。
动力方面,奥迪A3敞篷  版将搭载2.0TFSI汽油发动机和2.0TDI柴油发动机。此外新车还将推出两驱版车型和四驱版车型。新车最快将于2014年面世。
Audi A3 is a car product produced by Audi. It is developed based on the MQB platform of Volkswagen. Its body is made of lightweight design and aluminum material. It is equipped with 1.4tfsi and 1.8tfsi engines.
Built on the A3 three compartment model, the new car will most likely adopt the folding hood design. This new convertible will be the main competitor of BMW 2 Series Convertible in the future.
In terms of power, Audi A3 convertible will be equipped with 2.0 TFSI gasoline engine and 2.0 TDI diesel engine. In addition, the new car will also launch two-wheel drive model and four-wheel drive model. The new car will be available as soon as 2014.
奥迪A3的国内是常见的车型,比起奥迪A4它更加的平民化,也得到更多人的青睐,奥迪A3敞篷版搭载2.0TFSI汽油发动机和2.0TDI柴油发动机。此外新车还将推出两驱版车型和四驱版车型。于2014年上世。今天来分享奥迪A3改装气动避震低姿态的魅力,看看敞篷搭配低趴是不是更加的美!
Audi A3 is a common model in China. Compared with Audi A4, it is more civilian and more popular. Audi A3 convertible version is equipped with 2.0 TFSI gasoline engine and 2.0 TDI diesel engine. In addition, the new car will also launch two-wheel drive model and four-wheel drive model. It was born in 2014. Today, let's share the charm of Audi A3's modified pneumatic shock absorbers to see if the convertible is more beautiful with low-lying!
