查看: 633|回复: 0
“本色不改”带有怀旧情调 Ford Mustang气动避震悬挂套件完美低趴分享
发表于 2020-9-29 14:21:21 | 只看该作者 |只看大图 回帖奖励 |倒序浏览 |阅读模式
"True color" with nostalgic sentiment Ford Mustang pneumatic shock suspension package perfect low lying sharing
新款的野马外观设计比起上一代更加的时尚,流线设计更具跑车范,改装气动避震悬挂低姿态效果更是完美,国内的野马党就骚动起来,一台接着一台的改装低趴风格,来欣赏这辆野马气动避震悬挂低趴!
Compared with the previous generation, the appearance design of the new Mustang is more fashionable, the streamline design is more sports car style, the modified pneumatic shock absorber suspension low posture effect is more perfect, the domestic Mustang party is in a commotion, one by one refitting low lying style, to enjoy the Mustang pneumatic shock absorber suspension low lying down!
喜欢玩改装避震系统的发烧友,空气避震是话题里面最贵的一款。
听起来非常方便,气动避震到底是什么原理呢?
