查看: 653|回复: 0
斯巴鲁BRZ改装气动避震 体验低趴的舒适感
发表于 2020-9-28 15:55:08 | 只看该作者 |只看大图 回帖奖励 |倒序浏览 |阅读模式
Subaru brz refitted pneumatic shock absorbers for low lying comfort
斯巴鲁(片假名:スバル;罗马拼音:Subaru),台湾地区译作速霸陆,是富士重工业株式会社( FHI )旗下专业从事汽车制造的一家分公司,是生产多种类型、多用途运输设备的制造商。富士重工“斯巴鲁”汽车的标志采用六连星的形式。
斯巴鲁在日语中的意思是「昴」,其企业标志是昴宿星团的六连星(昴宿为按照中国古代的星座划分方法的星座名称),并且也是斯巴鲁汽车的标志。斯巴鲁的标志代表着第二次世界大战后,五个独立的公司一起组成了现今的斯巴鲁。斯巴鲁汽车拥有独特的技术,尤其是水平对卧式引擎和全时四轮驱动系统。斯巴鲁近年来业绩显著,2006年全球销售创下其历史记录。富士重工一直开发具有独特性的四轮驱动系统和高性能的水平对置式发动机。其四轮驱动系统,经过20多年的不断完善以及通过世界各地严酷的路况行驶经验,性能、质量不断提高。
In the Taiwan District, the company is a member of the Fuji Heavy Industries Company Limited (FHI). The company is a multi-purpose type, and it is a multi purpose system. Fuji Heavy Industries Co., Ltd.
In the case of Japan, the aim of the game is "Hai", and the rest of the plan is the six stars (the ancient constellation in China). This is the second most popular empress of the second world. It is a unique technique to be able to carry out the horizontal method, and all four times. It was held in 2006 by the whole country. Fuji Heavy Industries Co., Ltd. is a unique, quadruple, reliable, high quality hydraulic installation desk. In the meantime, there are twenty years of unfortunate success in the world.
减震器的工作原理主要用来抑制弹簧吸震后反弹时的震荡及来自路面的冲击。在经过不平路面时,虽然吸震弹簧可以过滤路面的震动,但弹簧自身还会有往复运动,而减震器就是用来抑制这种弹簧跳跃的。减震器的种类从产生阻尼材料的角度划分,减震器主要有液压和充气两种。
The working principle of the shock absorber is mainly used to suppress the shock of spring rebound and the impact from the road. Although the shock absorption spring can filter the vibration of the road surface when passing through the uneven road surface, the spring itself will have reciprocating motion, and the shock absorber is used to restrain the spring jumping. The types of shock absorbers are divided from the angle of producing damping materials. There are mainly two kinds of shock absorbers: hydraulic and pneumatic.
