查看: 790|回复: 0
奔驰C300改装气动避震完成心中低趴梦想
发表于 2020-9-28 14:19:29 | 只看该作者 |只看大图 回帖奖励 |倒序浏览 |阅读模式
Mercedes Benz C300 refitting pneumatic shock absorber to realize the dream of low lying in the heart
改装界流行一句话叫"百改降为先“我再补充一句,低趴才是王道!任何的改装如果没有气动避震改装的话,我感觉就像行尸走肉,徒有一个光鲜的外表,没有灵魂!正所谓一低遮百丑,气动避震改装是提升整车气质最关键的一笔! There is a popular saying in the field of refitting that "100 changes should be reduced to the first". I will add that low lying is the king's way! If there is no pneumatic shock absorber refitting, I feel like a walking corpse, with a bright appearance and no soul! As the so-called low cover hundred ugliness, pneumatic shock absorber refitting is the most critical to improve the quality of the vehicle!
